Configures an ESRP domain to track port connectivity to a specified VLAN.
| esrpDomain | Specifies an ESRP domain name. |
| vlan_name | Specifies the VLAN to be tracked. |
Disabled.
The track-vlan metric is derived from the total number of active physical ports on the VLAN being tracked by the ESRP domain.
If more than one VLAN shares a physical link, each VLAN counts the physical link.
The ESRP switch should have a higher priority number than its neighbors to ensure master election.
An ESRP domain can track one VLAN, and the tracked VLAN should not be a member of any other ESRP domain in the system.
The following command enables ESRP domain esrp1 to track port connectivity to VLAN engineering:
configure esrp esrp1 add track-vlan engineering
This command was first available in ExtremeXOS 11.0.
